Hi all,
Following on from Allen's post of fitting an inverter under the seat of his Scarabeo 500ie to charge/power his laptop, I thought of doing something similar for a GPS unit. My initial plan was to install a 12v socket under the seat and to plug in my Navman. This could then transmit to a bluetooth headphone unit to give the voice directions, as an alternative to mounting the unit on the handlebars using a clamp fitting.
Has anyone successfully tried a GPS on a scooter or does the bounce pretty well prevent one from being able to read the screen? Is the day glare too bright for the screen? My "solution" adds the cost of a bluetooth transmitter/receiver, around $200+, to that of the GPS, but you can still use the GPS system in the car when you need to. Was a little worried too of what rain/dust would do to an exposed GPS. Oh yes and then there's theft.
Am still toying with the idea of taking big red Audrey up the East Coast to northern NSW, Sth QL'd, but it's hard consulting maps and street directories with two hands on the handlebars
I got the local Auto Electric place to put together a 30cm cable, with battery eyelets at one end, and a rubber capped 12v socket at the other. Fitted easily, and tucks away neatly when not in use. Before I started looking at the range of bluetooth transmitter/receivers, thought I'd ask for feedback.
Taaaah, Mike
