Hi dozer,
My distances really vary because I live up in Kuranda (15 klm mostly up hill & mostly a 60km/hr limit), but I'll give a typical example.
When I go to Cairns which is about a 33 km trip I only use about 1/2 the battery. And going down hill I don't use much + it regenerates up to 12%. While in Cairns I've got 2 shopping ctrs I can plug in at (so far). I just tell them I'm there-no charge. I usually charge it for an hour while I'm shopping & this gets me home again. Going home takes more 'juice' as it's up hill, so I usually use about 12 of 17 bars that show the amount of battery I have left. It takes about 10 min. per bar to charge so that should give you an idea. It takes longer for it to go through it's whole reconditioning process (4-6 hrs) which I do once I get home.
It costs me 55-65 cents for a full charge. I checked it with one of those energy meters you can get from the library.
So back to the distances. If you are just buzzing around town you can probably get 80-90km. At 90km/hr I reckon I'd get 35-40km. I still have to test this one out as most of my trips are either local or down to cairns. I've had it up to it's maximum of 105km/hr - very smooth.
Hardly ever use the brakes because of the regeneration system - acts like an air brake on a truck. And I love having reverse. Since the bike is over 200 kilos it really helps.
For me, when I get on the Vectrix it's like climbing into/onto a limo. Verrrry comfortable.
Joolz-V
